[Qgis-user] Merge XLS with a ShapeFile
Andreas Neumann a.neumann at carto.net
Tue Feb 28 12:17:41 PST 2012
You can use the table join feature in the layer properties.
See section 4.4.11. Joins Tab in the QGIS manual
(http://download.osgeo.org/qgis/doc/manual/qgis-1.7.0_user_guide_en.pdf)
Note that XLS files are only recently supported in QGIS trunk. QGIS 1.7
does not support them yet - however, you can save the xls file to a dbf
file, e.g. by using LibreOffice.
Andreas
On 02/28/2012 09:06 PM, Leandro Marino wrote:
> Hi,
> I'm newbie in this mailing list. Sorry if this question has an duplicated
> in the list. I didn't find a search function in the mailing list website.
> I want to merge an Xls file with a ShapeFile. This shapefile has about 1300
> records of points (schools). How can I do that? These databases have only
> one common column (ID).
> Thanks.
> Any help will be appreciated.
> Regards,
> Leandro Marino
> Qgis-user mailing list
