[Qgis-user] Merge XLS with a ShapeFile
Leandro Marino
leandromarino at leandromarino.com.br
Tue Feb 28 12:22:30 PST 2012
*Andreas,*
*Thanks!*
*I'll try to do that.*
*Atenciosamente,
Leandro Marino
http://www.leandromarino.com.br (Fotógrafo)
http://est.leandromarino.com.br/Blog (EstatÃstico)
Cel.: + 55 21 9845-7707
Cel.: + 55 21 8777-7907
2012/2/28 Andreas Neumann <a.neumann at carto.net>
> Hi,
> You can use the table join feature in the layer properties.
> See section 4.4.11. Joins Tab in the QGIS manual
> (http://download.osgeo.org/qgis/doc/manual/qgis-1.7.0_user_guide_en.pdf)
> Note that XLS files are only recently supported in QGIS trunk. QGIS 1.7
> does not support them yet - however, you can save the xls file to a dbf
> file, e.g. by using LibreOffice.
> Andreas
> On 02/28/2012 09:06 PM, Leandro Marino wrote:
> > Hi,
> > I'm newbie in this mailing list. Sorry if this question has an duplicated
> > in the list. I didn't find a search function in the mailing list website.
> > I want to merge an Xls file with a ShapeFile. This shapefile has about
> 1300
> > records of points (schools). How can I do that? These databases have only
> > one common column (ID).
> > Thanks.
> > Any help will be appreciated.
> > Regards,
> > Leandro Marino
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120228/8bf60026/attachment.html>
