[Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
Donovan Cameron
sault.don at gmail.com
Tue Feb 28 13:59:32 PST 2012
So I got it [SOLVED] for my system(s)!
I checked python and the proper version was installed.
The problem was what Sascha had pointed out with my Qt and KDE version.
I then did a fresh install of OpenSUSE 12.1 x64 on my laptop and just did
regular upgrades without upgrading to KDE 4.8.
So therefore, I will NOT UPGRADE to KDE 4.8!
Everything is working fine now. Thanks for pointing this out.
Donovan
On Tue, Feb 28, 2012 at 5:25 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com>wrote:
> Hi Brent,
> I am trying to reproduce this issue without results at the moment.
> Looking more into this.
> Regards,
> Angelos
> On 02/27/2012 11:03 PM, pcreso at pcreso.com wrote:
> Hi Angelos,
> I just installed QGIS 1.74 (from 1.73 which worked fine) on OpenSuse 12.1
> 64bit.
> It is now broken with a startup error message as below.
> My libpython was 2.7 from the standard repository. This had the same
> version as the python repo you suggested.
> QGIS is running, but with no python support, my system is fully updated as
> far as I can tell.
> Any advice/fixes appreciated...
> Thanks,
> Brent
> Error msg below
> _____________________________________________________________
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
> File "", line 1, in
> ImportError: /usr/share/qgis/python/qgis/core.so: undefined symbol: _ZNK7QObject17senderSignalIndexEv
> Python version:
> 2.7.2 (default, Aug 19 2011, 20:41:43) [GCC]
> QGIS version:
> 1.7.4-Wroclaw 'Wroclaw', exported
> ________________________________________________________________
> --- On *Tue, 2/28/12, Angelos Tzotsos <gcpp.kalxas at gmail.com><gcpp.kalxas at gmail.com>
> * wrote:
> From: Angelos Tzotsos <gcpp.kalxas at gmail.com> <gcpp.kalxas at gmail.com>
> Subject: Re: [Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
> To: qgis-user at lists.osgeo.org
> Date: Tuesday, February 28, 2012, 6:47 AM
> Hi,
> QGIS 1.7.4 works fine in my machines
> You should add this repository in your system:
> http://download.opensuse.org/repositories/devel:/languages:/python/openSUSE_12.1/
> update and try installing qgis again
> Regards,
> Angelos
> On 02/27/2012 06:24 PM, Donovan Cameron wrote:
> I noticed my error when QGIS upgraded to 1.7.3 as well, but never got
> around to reporting it, then 1.7.4 came out soon afterwards. It opened and
> ran fine in v 1.7.2
> I will check my python version when I get home tonight and see if that
> could be it if not, I may rollback to 1.7.2.
> I'll follow your forum thread for updates as well.
> Donovan
> On Mon, Feb 27, 2012 at 8:24 AM, Kerick Leite <kerick.quimica at gmail.com<http://mc/compose?to=kerick.quimica@gmail.com>
> > wrote:
> I had a problem with the installation of QGIS 1.7.3 in the same version of
> OpenSUSE as yours. The problem was caused by a missing dependency also
> related to python. I've posted the problem in the forum, but so far there
> wasn't a reply:
> http://forum.qgis.org/viewtopic.php?f=3&t=10012&sid=76d8f641ce6c9e16198adf6ef41b52e6
> Regards,
> Kerick
> Message: 6
> Date: Sun, 26 Feb 2012 16:38:10 -0700
> From: Donovan Cameron <sault.don at gmail.com<http://mc/compose?to=sault.don@gmail.com>
> Subject: [Qgis-user] QGIS 1.7.4 doesn't run in OpenSUSE 12.1
> To: qgis-user at lists.osgeo.org<http://mc/compose?to=qgis-user@lists.osgeo.org>
> Message-ID:
> <CAJo0jfPr+K5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw at mail.gmail.com<http://mc/compose?to=CAJo0jfPr%2BK5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw@mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> When I try to run qgis from the terminal, the splash shows, but as soon as
> it gets to the part "Starting Python" the splash simply closes.
> The output from the terminal is:
> *qgis: siplib.c:10938: sipEnumType_alloc: Assertion
> `(((currentType)->td_flags & 0x0007) == 0x0003)' failed.*
> *Aborted*
> I downloaded and installed QGIS from the "geo" repository (
> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_12.1/)
> QGIS: 1.7.4-Wroclaw
> OS: OpenSUSE 12.1 with KDE 4.8
> Kernel: 3.1.9-1.4-desktop
> Regards,
> Donovan
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20120226/8bedc4f5/attachment-0001.html
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <http://mc/compose?to=Qgis-user@lists.osgeo.org>
> Qgis-user mailing listQgis-user at lists.osgeo.org <http://mc/compose?to=Qgis-user@lists.osgeo.org>http://lists.osgeo.org/mailman/listinfo/qgis-user
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athenshttp://users.ntua.gr/tzotsos
> -----Inline Attachment Follows-----
> Angelos Tzotsos
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120228/428a668f/attachment.html>
