[Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
Angelos Tzotsos
gcpp.kalxas at gmail.com
Tue Feb 28 14:19:28 PST 2012
Hi Donovan,
Builds in OBS assume that only the default repositories are used, with
default packages, so updating manually KDE or Qt might cause such problems.
The only solution to use latest software AND have all packages tested
against them is Tumbleweed:
http://en.opensuse.org/Portal:Tumbleweed
Regards,
Angelos
On 02/28/2012 11:59 PM, Donovan Cameron wrote:
> So I got it [SOLVED] for my system(s)!
> I checked python and the proper version was installed.
> The problem was what Sascha had pointed out with my Qt and KDE version.
> I then did a fresh install of OpenSUSE 12.1 x64 on my laptop and just
> did regular upgrades without upgrading to KDE 4.8.
> So therefore, I will NOT UPGRADE to KDE 4.8!
> Everything is working fine now. Thanks for pointing this out.
> Donovan
> On Tue, Feb 28, 2012 at 5:25 AM, Angelos Tzotsos
> <gcpp.kalxas at gmail.com <mailto:gcpp.kalxas at gmail.com>> wrote:
> Hi Brent,
> I am trying to reproduce this issue without results at the moment.
> Looking more into this.
> Regards,
> Angelos
> On 02/27/2012 11:03 PM, pcreso at pcreso.com
> <mailto:pcreso at pcreso.com> wrote:
>> Hi Angelos,
>> I just installed QGIS 1.74 (from 1.73 which worked fine) on
>> OpenSuse 12.1 64bit.
>> It is now broken with a startup error message as below.
>> My libpython was 2.7 from the standard repository. This had the
>> same version as the python repo you suggested.
>> QGIS is running, but with no python support, my system is fully
>> updated as far as I can tell.
>> Any advice/fixes appreciated...
>> Thanks,
>> Brent
>> Error msg below
>> _____________________________________________________________
>> Couldn't load PyQGIS.
>> Python support will be disabled.
>> Traceback (most recent call last):
>> File "", line 1, in
>> ImportError: /usr/share/qgis/python/qgis/core.so: undefined symbol: _ZNK7QObject17senderSignalIndexEv
>> Python version:
>> 2.7.2 (default, Aug 19 2011, 20:41:43) [GCC]
>> QGIS version:
>> 1.7.4-Wroclaw 'Wroclaw', exported
>> ________________________________________________________________
>> --- On *Tue, 2/28/12, Angelos Tzotsos /<gcpp.kalxas at gmail.com>
>> <mailto:gcpp.kalxas at gmail.com>/* wrote:
>> From: Angelos Tzotsos <gcpp.kalxas at gmail.com>
>> Subject: Re: [Qgis-user] Re: QGIS 1.7.4 doesn't run in
>> OpenSUSE 12.1
>> To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>> Date: Tuesday, February 28, 2012, 6:47 AM
>> Hi,
>> QGIS 1.7.4 works fine in my machines
>> You should add this repository in your system:
>> http://download.opensuse.org/repositories/devel:/languages:/python/openSUSE_12.1/
>> update and try installing qgis again
>> Regards,
>> Angelos
>> On 02/27/2012 06:24 PM, Donovan Cameron wrote:
>>> I noticed my error when QGIS upgraded to 1.7.3 as well, but
>>> never got around to reporting it, then 1.7.4 came out soon
>>> afterwards. It opened and ran fine in v 1.7.2
>>> I will check my python version when I get home tonight and
>>> see if that could be it if not, I may rollback to 1.7.2.
>>> I'll follow your forum thread for updates as well.
>>> Donovan
>>> On Mon, Feb 27, 2012 at 8:24 AM, Kerick Leite
>>> <kerick.quimica at gmail.com
>>> <http://mc/compose?to=kerick.quimica@gmail.com>> wrote:
>>> I had a problem with the installation of QGIS 1.7.3 in
>>> the same version of OpenSUSE as yours. The problem was
>>> caused by a missing dependency also related to python.
>>> I've posted the problem in the forum, but so far there
>>> wasn't a reply:
>>> http://forum.qgis.org/viewtopic.php?f=3&t=10012&sid=76d8f641ce6c9e16198adf6ef41b52e6
>>> <http://forum.qgis.org/viewtopic.php?f=3&t=10012&sid=76d8f641ce6c9e16198adf6ef41b52e6>
>>> Regards,
>>> Kerick
>>> Message: 6
>>> Date: Sun, 26 Feb 2012 16:38:10 -0700
>>> From: Donovan Cameron <sault.don at gmail.com
>>> <http://mc/compose?to=sault.don@gmail.com>>
>>> Subject: [Qgis-user] QGIS 1.7.4 doesn't run in
>>> OpenSUSE 12.1
>>> <http://mc/compose?to=qgis-user@lists.osgeo.org>
>>> Message-ID:
>>> <CAJo0jfPr+K5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw at mail.gmail.com
>>> <http://mc/compose?to=CAJo0jfPr%2BK5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw@mail.gmail.com>>
>>> Content-Type: text/plain; charset="iso-8859-1"
>>> When I try to run qgis from the terminal, the splash
>>> shows, but as soon as
>>> it gets to the part "Starting Python" the splash
>>> simply closes.
>>> The output from the terminal is:
>>> *qgis: siplib.c:10938: sipEnumType_alloc: Assertion
>>> `(((currentType)->td_flags & 0x0007) == 0x0003)'
>>> failed.*
>>> *Aborted*
>>> I downloaded and installed QGIS from the "geo"
>>> repository (
>>> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_12.1/)
>>> QGIS: 1.7.4-Wroclaw
>>> OS: OpenSUSE 12.1 with KDE 4.8
>>> Kernel: 3.1.9-1.4-desktop
>>> Regards,
>>> Donovan
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL:
>>> http://lists.osgeo.org/pipermail/qgis-user/attachments/20120226/8bedc4f5/attachment-0001.html
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> <http://mc/compose?to=Qgis-user@lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Qgis-user at lists.osgeo.org <http://mc/compose?to=Qgis-user@lists.osgeo.org>
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athens
>> http://users.ntua.gr/tzotsos
>> -----Inline Attachment Follows-----
> Angelos Tzotsos
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
Angelos Tzotsos
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120229/b551d2db/attachment.html>
