[Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
Otto Dassau
dassau at gbd-consult.de
Wed Feb 29 00:08:51 PST 2012
Angelos is right. Building QGIS for Application:Geo is based on packages from
the default repositories (python, ...) and from Application:Geo (geos,
gdal, ...). If you use other repositories for kde, qt, python etc. qgis will
likely fail.
I hope this explains your problems.
Tumbleweed in my opinion should only be used, if you are an experienced
opensuse user.
Kind regards
Otto
Am Wed, 29 Feb 2012 00:19:28 +0200
schrieb Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> Hi Donovan,
> Builds in OBS assume that only the default repositories are used, with
> default packages, so updating manually KDE or Qt might cause such problems.
> The only solution to use latest software AND have all packages tested
> against them is Tumbleweed:
> http://en.opensuse.org/Portal:Tumbleweed
> Regards,
> Angelos
> On 02/28/2012 11:59 PM, Donovan Cameron wrote:
> > So I got it [SOLVED] for my system(s)!
> > I checked python and the proper version was installed.
> > The problem was what Sascha had pointed out with my Qt and KDE version.
> > I then did a fresh install of OpenSUSE 12.1 x64 on my laptop and just
> > did regular upgrades without upgrading to KDE 4.8.
> > So therefore, I will NOT UPGRADE to KDE 4.8!
> > Everything is working fine now. Thanks for pointing this out.
> > Donovan
