[Qgis-user] Offset curve tool
Nathan Woodrow
madmanwoo at gmail.com
Wed Feb 29 02:31:29 PST 2012
A suggestion I would have is to not put the Offset spin box in the status
bar area. IMO it would be better in a floating dialog like the measure
tool. This would allow more options, or info, to be added to the tool
later.
Also if editing the value doesn't change the result of the tool I would
think it would be good as read-only. I tried to edit it in order to order
to supply a offset of 3 and nothing happened.
- Nathan
On Wed, Feb 29, 2012 at 8:11 PM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
> Hi all
> There is a new editing tool in the master branch.
> The offset curve tool creates parallel shifts of linestrings and polygon
> rings ( single sided buffers with the geos function GEOSSingleSidedBuffer
> ). The tool can be applied to the edited layer (the geometries are
> modified) or also to background layers (creates copies of the lines / rings
> and adds it to the the edited layer). It is thus ideally suited for the
> creation of distance line layers.
> Let me know about issues, suggestions, comments.
> The work was kindly funded by the city of Uster (Switzerland).
> Regards,
> Marco
> Dr. Marco Hugentobler
> Sourcepole - Linux& Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.**ch <marco.hugentobler at sourcepole.ch>
> http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120229/01eaec3e/attachment.html>
