[Qgis-user] Offset curve tool
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Feb 29 03:17:16 PST 2012
Hi Nathan
 >A suggestion I would have is to not put the Offset spin box in the
status bar area.  IMO it would be better in a floating dialog like the
measure tool.  This would allow more >options, or info, to be added to
the tool later.
On Mac OS and Windows, the spin box is placed next to the cursor and
moves with it. On X11, I had to disable that because there is a problem
embedding widget items if the flag Qt::WA_PaintOnScreen is set on the
canvas.
But yes, it might be better to have a separate window on X11.
 >Also if editing the value doesn't change the result of the tool I
would think it would be good as read-only. I tried to edit it in order
to order to supply a offset of 3 and nothing >happened.
It is intended that editing changes the result. After pressing the
return key, the offset line should move to the new distance (but the
mouse should not be moved, otherwise it will be overriden by the
following mouse move position). Doesn't this work for you?
Regards,
Marco
> measure tool.  This would allow more options, or info, to be added to
> the tool later.
> to order to supply a offset of 3 and nothing happened.
> - Nathan
> On Wed, Feb 29, 2012 at 8:11 PM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch
> <mailto:marco.hugentobler at sourcepole.ch>> wrote:
>     Hi all
>     There is a new editing tool in the master branch.
>     The offset curve tool creates parallel shifts of linestrings and
>     polygon rings ( single sided buffers with the geos function
>     GEOSSingleSidedBuffer ). The tool can be applied to the edited
>     layer (the geometries are modified) or also to background layers
>     (creates copies of the lines / rings and adds it to the the edited
>     layer). It is thus ideally suited for the creation of distance
>     line layers.
>     Let me know about issues, suggestions, comments.
>     The work was kindly funded by the city of Uster (Switzerland).
>     Regards,
>     Marco
>     Dr. Marco Hugentobler
>     Sourcepole -  Linux&  Open Source Solutions
>     Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>     <mailto:marco.hugentobler at sourcepole.ch> http://www.sourcepole.ch
>     Technical Advisor QGIS Project Steering Committee
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120229/28745026/attachment.html>
