[Qgis-user] Problem in loading PostGIS table into QGIS
Siki Zoltan siki at agt.bme.hu
Thu Jan 5 09:50:43 PST 2012
Dear Imas,
you can add spatial enabled PostGIS tables to your QGIS project.
The PostGIS table must have an integer (int4) primary key column and a
geometry column. Check your tables.
Regards
Zoltan
On Thu, 5 Jan 2012, Imas Sitanggang wrote:
> Hi all QGIS users, I have a problem in loading PostGIS table into QGIS. In
> the dialog window ˙˙Add Postgis Table(s), I cannot found the recently
> created tables in the database PostgreSQL.  So I cannot load it into
> GGIS project.  Before this, I found new created layers in the window with
> the value ˙˙Waiting˙˙ in the colomn Type, but now there are only
> POLYGON, LINE, MULTIPOLYGON, and POINT appear in the coloum Type.
> Anyone, kindly give me any solution to my problem.
> Thank you
> Imas Sitanggang
