[Qgis-user] Re: Mapbooks with Easyprint
    Alister Hood
    alister.hood at synergine.com
    Sat Jan  7 04:57:42 PST 2012
> Date: Thu, 05 Jan 2012 11:34:44 +0100
> From: "Wolf-E. Altmann" <mailinglists at envitelligence.de>
> Subject: Re: [Qgis-user] Re: Mapbooks with Easyprint
> To: magerlin <MAP at ramboll.dk>, user Qgis <Qgis-user at lists.osgeo.org>
> Message-ID: <4F057CC4.9040800 at envitelligence.de>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Am 04.01.2012 10:00, schrieb magerlin:
> > Hi
> > The EasyPrint mapbook is a very usefull feature!
> > Could one add a feature to reverse the page order in the final PDF (when
> > ticking "Print single file")?
> > I am working with a road section running north-south and in the pdf the maps
> > are shown from south to north.
> > I would find it more logical to have the reverse order so north will be at
> > the top of the document and south at the bottom when I scroll through the
> > PDF.
> > And I would also like the possibility to get the overview map as first page?
> > Regards Morten
> > (Qgis 1.7.3 standalone and Win 7)
> > View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapbooks-with-Easyprint-tp6475315p7149688.html
> > Sent from the qgis-user mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Hi Morten,
> if you use Linux and your mapbook hasn't to much pages you can try "PDF
> Mod" for manually reordering PDF-Documents.
> Wolf
Or you could try Pdfshuffler or Final Page, both available on sourceforge.  I think in theory any of them could work on Windows, but I know there is already a (third party) windows installer for pdfshuffler (if you can find it - it is linked from one of the bug reports).
But if you just want to reverse the pages, the easiest thing to do is open the pdf and "print to file", selecting the option to reverse the page order.  On windows and some other systems you would need to install a virtual "pdf printer" such as PdfCreator (also available on sourceforge) and print to that.
BTW I think if you wanted to file a bug report or a patch for easy print this would be the place: http://code.google.com/p/cataisrepository/issues/list
Alister
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120108/d074212a/attachment.bin>
