[Qgis-user] shape file in wrong position
Giovanni Manghi
giovanni.manghi at faunalia.pt
Mon Jan 16 12:33:22 PST 2012
try the "qgsaffine" plugin.
cheers
On Mon, 2012-01-16 at 21:31 +0100, Thomas Weihrauch wrote:
> Hi,
> for the project and every layer i have set the same projected system (a projected UTM zone) but i have an offset on the shape-file. The overlay-layer has coordinates about 300.000 x 5.000.000 and the shape has 3.300.000 x 5.000.000. So basically i need to reposition the shape about -3.000.000. The shapes are from an old ArcView version.
> Thank you
> Thomas
> -----Ursprüngliche Nachricht-----
> Von: "Alexander Bruy" <alexander.bruy at gmail.com>
> Gesendet: 16.01.2012 19:55:31
> An: "Thomas Weihrauch" <jones at txm.de>
> Betreff: Re: [Qgis-user] shape file in wrong position
> >Hi
> >seems your shapefiles and overlay layers are in different CRS. You
> >shpould reproject
> >your shapefile into same CRS as overlay or enable on the fly
> >reprojection in project
> >properties
> >2012/1/16 Thomas Weihrauch <jones at txm.de>:
> >> Hi,
> >> i have old shape-files i want to load into QGIS 1.7.3. But they are at the wrong position. If i try to overlay it with some Webservice-Maps its totally wrong. Can i correct the offset of the shape-files during load? Its about 3000000 Units away from the original position. Do you have an idea where i can look into that problem?
> >Alexander Bruy
> ___________________________________________________________
> SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
> kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
> Qgis-user mailing list
