[Qgis-user] shape file in wrong position
Thomas Weihrauch
jones at txm.de
Tue Jan 17 12:55:33 PST 2012
hi,
this plugin works with one flaw, i cannot zoom to the layer with right-click to layer and zoom to layer extent shows only an empty window but zooming to overlay shows both now.
thank you
Thomas
-----Ursprüngliche Nachricht-----
Von: "Giovanni Manghi" <giovanni.manghi at faunalia.pt>
Gesendet: 16.01.2012 21:33:22
An: "Thomas Weihrauch" <jones at txm.de>
Betreff: Re: [Qgis-user] shape file in wrong position
>try the "qgsaffine" plugin.
>cheers
>On Mon, 2012-01-16 at 21:31 +0100, Thomas Weihrauch wrote:
>> Hi,
>> for the project and every layer i have set the same projected system (a projected UTM zone) but i have an offset on the shape-file. The overlay-layer has coordinates about 300.000 x 5.000.000 and the shape has 3.300.000 x 5.000.000. So basically i need to reposition the shape about -3.000.000. The shapes are from an old ArcView version.
>> Thank you
>> Thomas
>> Von: "Alexander Bruy" <alexander.bruy at gmail.com>
>> Gesendet: 16.01.2012 19:55:31
>> >Hi
>> >seems your shapefiles and overlay layers are in different CRS. You
>> >shpould reproject
>> >your shapefile into same CRS as overlay or enable on the fly
>> >reprojection in project
>> >properties
>> >2012/1/16 Thomas Weihrauch <jones at txm.de>:
>> >> Hi,
>> >> i have old shape-files i want to load into QGIS 1.7.3. But they are at the wrong position. If i try to overlay it with some Webservice-Maps its totally wrong. Can i correct the offset of the shape-files during load? Its about 3000000 Units away from the original position. Do you have an idea where i can look into that problem?
>> >Alexander Bruy
>> ___________________________________________________________
>> SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
>> kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
