[Qgis-user] Re: Request
Mauricio de Paulo
mauricio.dev at gmail.com
Tue Jan 24 09:04:21 PST 2012
The link I posted is to download the 0.4.2 zip file. You should unzip it
in your ~/.qgis/python/plugins on linux. On windows I think it's
c:\documents and settings\username\.qgis\python\plugins.
This is how you can manually install a python plugin.
All the best.
Mauricio C. M. de Paulo
Engenheiro Cartógrafo
Mestrando em Sensoriamento Remoto (INPE)
On 01/24/2012 02:57 PM, Deepak R aj Awasthi wrote:
> Thanks for prompt reply.
> Currently it will be sufficient for me if the older version of the
> plugin will work. You mean to say that I can use the 0.4.2 version?.
> Actually I have not that much idea about the QGIS even , can you
> please guide me on installing the zipped file of plugin in QGIS.
> Although I add the link you provided in the Fetch Python
> plugin->Repositories,but it does not show the plugin in plugins menu.
> I will be really thank full to you.
> *From:* Mauricio de Paulo <mauricio.dev at gmail.com>
> *To:* Deepak R aj Awasthi <deepakrajawasthi at yahoo.com>;
> *Sent:* Tuesday, 24 January 2012, 17:25
> *Subject:* Re: Request
> Hi, Deepak.
> Thanks for using the wktraster plugin. I think I might know what
> happened to your setup. Please tell me if I guessed wrong.
> Postgis SVN is under some harsh changes. I've recently uploaded
> wktraster version 0.5.3 in order to handle some of these changes.
> Many changes made in the recent postgis 2.0 SVN updates made it
> impossible to use the same databases that we worked with last year.
> This means that you have to either upgrade your database or build a
> new one.
> I think that there is a script to upgrade the database in the SVN
> tree. You can search for it near the rt_postgis.sql file.
> You probably noticed that the plugin isn't uploading raster to
> database for now. It's also a consequence of the recent changes and
> should be solved when the work on the postgis 2.0 raster loaders is done.
> I'm sorry that you are having problems because of the update. If you
> wish to keep the old database, the older version of the plugin should
> still work. You can download it at:
> http://plugins.qgis.org/plugins/wktraster/
> All the best,
> On 01/24/2012 02:15 PM, Deepak R aj Awasthi wrote:
>> Dear Sir,
>> I got problem with the QGIS plugin wktraster 0.5.3 which can be used
>> to view postgis raster. I am using PostgreSQL 9.0, PostGIS the latest
>> release for 9.0 i.e. postGIS 2.0.0 released on 2012-01-07 and GDAL 1.8
>> Initially I was using PostgreSQL 9.0, and Postgis 2.0.0 released date
>> 2011-10-7 and GDAL 1.8. While using this configuration I able to view
>> the postGIS raster table in the QGIS 1.7.1 with plugin wktraster 0.5.1.
>> When I upgrade PostGIS to latest version and try to view the raster
>> table in QGIS , I have to update QGIS plugin to 0.5.3. but it is not
>> working now. What could be the problem. Whenever I access the menu
>> Database->PostGIS raster->Add a PostGIS raster layer, the error
>> window appear with title "error". I have attached the dump of that
>> error window.
>> Sorry to send directly mail, it would be better to send on some blog
>> but I am unable to find the suitable one.
>> Thanks in advance
>> Regards,
>> Deepak
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120124/2eb5a719/attachment.html>
