[Qgis-user] Atlas plugin - create map books
Nathan Woodrow
madmanwoo at gmail.com
Wed Jan 25 01:06:12 PST 2012
I can let you use Composer windows to create the map books.
- Nathan
On Wed, Jan 25, 2012 at 6:51 PM, Paolo Cavallini <cavallini at faunalia.it>wrote:
> Il 25/01/2012 09:48, Vincent Picavet ha scritto:
> > Hi,
> > A quick message to point you to a new «Atlas» plugin, which let you
> > create pdf map books given a layer defining map zones.
> > The plugin is available in the experimental part of the new plugin
> > repository.
> > A few links :
> > http://www.oslandia.com/tech/?p=1079
> > http://hub.qgis.org/projects/atlas
> > http://plugins.qgis.org/plugins/atlas/
> Thanks a lot.
> What is the difference between this and the EasyPrint>MapBook plugin?
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120125/8173b3be/attachment.html>
