[Qgis-user] Atlas plugin - create map books
Luca Lanteri
mescal72 at gmail.com
Wed Jan 25 01:53:28 PST 2012
FANTASTIC !
The estension is just the improvement of easyprint that I need for my work.
- it uses the composer for layout instead of xml file,
- there isn't limitation in the number of custom field,
- output in different format.
in the next days I'll try to use it and I hope to send some useful feedback
many thanks to OSLANDIA.
2012/1/25 Vincent Picavet <vincent.ml at oslandia.com>
> Hi,
> A quick message to point you to a new «Atlas» plugin, which let you
> create pdf map books given a layer defining map zones.
> The plugin is available in the experimental part of the new plugin
> repository.
> A few links :
> http://www.oslandia.com/tech/?p=1079
> http://hub.qgis.org/projects/atlas
> http://plugins.qgis.org/plugins/atlas/
> I hope it will be useful to you :)
> Vincent
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120125/27d0b7ae/attachment.html>
