[Qgis-user] Re: Qgis reports
Josef K groundwatergis at gmail.com
Mon Jan 30 02:07:20 PST 2012
Hi Chuck
I do not have any good solution for getting the reports but I do work with
joined tables containing extra info connected to features in a vector
leayer. In my case the extra info is time series data and I wrote a simple
(experimental) plugin called *TimeSeriesPlot* for this. The plugin reads ID
for the selected objects in a vector layer and extracts the corresponding
data from a non-spatial table stored in a spatialite db. You can download
the plugin from the respository for user-contributed plugins. Perhaps you
find some code snippets to use if you want to write your own plugin.
regards
Josef
> On Sat, Jan 21, 2012 at 6:46 PM, Chuck Young <wylie1066 at gmail.com> wrote:
> > Is anyone using Qgis with joined tables that contain extra info connected
> > to a point or polygon where the data is displayed in a report which
> > contains a n image of the polygon along with a table containing the
> relate
> > info, which is contained in the joined table?
> > If so I would really appreciate getting to understand the process and how
> > to implement it.  Are there any plugins that work like that?  I see some
> > that seem to indicate that in their titles but I am unsure.
> > What I have is a SpatialLite db for the vector layers (Polygons, lines,
> > and points).  I have a table in the db for related data with
> corresponding
> > ID fields for relational connectivity.  I want to be able to click a
> > polygon etc., within the QGIS window,and display the report or print it
> in
> > a predefined format. Or at least be able to click the entity and have a
> > popup display this info,
> > Thanks for any help!
> > Chuck
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120130/230a4da7/attachment.html>
