[Qgis-user] 'gdawarp' causing shift and other questions
Even Rouault
even.rouault at mines-paris.org
Mon Jan 30 06:13:48 PST 2012
Selon Etienne Tourigny <etourigny.dev at gmail.com>:
> 1) Probably a datum issue, as shapefiles do not include datum shift
> information. You could work this around by making a new shape file
> with the same datum as the gtiff file.
> What are the datums of your gtiff and shape files? Please post the
> contents of the .prj file.
It might be the same as http://trac.osgeo.org/gdal/ticket/3947
> Etienne
> On Mon, Jan 30, 2012 at 9:39 AM, Tilottama Ghosh <waggymaggy at gmail.com>
> wrote:
> > Hi,
> > I have a huge tiff image (covering an entire country) with 3399 columns and
> > 3747 rows, so a total of 12,736,053 cells. The cell size is 1000m or 1km. I
> > need to extract the data per km2. Of course, I didn't think it was smart to
> > work with such a huge dataset in one go. So, I followd these steps in
> > Quantum gis -
> > 1. I used the gdalwarp -crop_to_cutline in the command line to carve out a
> > portion of the raster image based on the shapefile of a state of the
> entire
> > country. The problem is that although the gdalwarp command worked it is
> > clearly causing a shift (of about 500m) during this step.
> > 2. Then, I used the gdal2xyz tool from the command line to create the csv
> > file corresponding to the 'cut out' raster image or only the raster image
> of
> > the state.
> > 3. Then I used the 'Create a Layer from a Delimited Text file' plugin in
> > qgis to get the centroid shapefile.
> > My problems are-
> > 1. The shift in the image caused by the gdalward tool. Does anyone know how
> > to work around that, so that no shift is caused?
> > 2. The image is in 32 bit floating point and so does not show the attribute
> > table. Even after getting the csv file I am unable to link the created csv
> > file with the raster image, and thus cannot understand which pixel
> > corresponds to which value in the csv file.
> > Can anyone suggest any better way of doing this?
> > Thanks very much for your help.
> > Best Regards,
> > Tilo
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
