[Qgis-user] Converting CSV into a database
    pcreso at pcreso.com
    Mon Jan 30 09:52:35 PST 2012
I suggest you use QGIS as a WMS server, or use the "export Mapserver" plugin & use Mapserver to create an interactive web page with your comtent. A fully interactive website is perhaps the best way to demonstrate the functionality.
I have also created a Linux Live DVD with QGIS, the required data and a suitable project set up. This provides a bootable DVD from which users can boot directly into a QGIS application on any standard PC, without interfering with the current PC setup. A very elegant way of doing what you suggest. This is also now apparently possible with Windows: http://www.makeuseof.com/tag/how-to-create-your-own-custom-windows-live-cd/
Cheers,
   Brent Wood
--- On Tue, 1/31/12, Gerhardus Geldenhuis <gerhardus.geldenhuis at gmail.com> wrote:
From: Gerhardus Geldenhuis <gerhardus.geldenhuis at gmail.com>
Subject: Re: [Qgis-user] Converting CSV into a database
To: tech at wildintellect.com
Cc: qgis-user at lists.osgeo.org
Date: Tuesday, January 31, 2012, 6:18 AM
Hi Alex,The Plugin Installer if that is a plugin itself then it is not listed.
The keyservers have not been working for a while and that breaks any other updates. Which means I have to deselect any QGIS related updates every time ubuntu updates my laptop.
This is my listed repositories:deb     http://qgis.org/debian natty maindeb-src http://qgis.org/debian natty main
and I am definitely using natty and have not upgraded my OS.
Regards
On 29 January 2012 19:10, Alex Mandel <tech_dev at wildintellect.com> wrote:
Check in the Manage Plugins menu that you have the Plugin Installer enabled.
The authentication thing is no big deal sometimes the keyservers just
aren't working. As a question of clarification which repository are you
installing QGIS from?
Thanks,
Alex
On 01/29/2012 04:40 AM, Gerhardus Geldenhuis wrote:
> Hi
> That installation unfortunately had no effect. Still no python plugin menu
> option. In addition I also get the message:
> WARNING: The following packages cannot be authenticated!
>   libqgis1.7.3 python-qgis python-qgis-common
> Install these packages without verification [y/N]? y
> which I ignored
> I ran sudo ldconfig thinking maybe a link somewhere is missing but that did
> not do the trick either. The packages were installed previously:
> Preparing to replace python-qgis 1.4.0+12730-5ubuntu1 (using
> .../python-qgis_1.7.3-1~natty1_i386.deb) ...
> Unpacking replacement python-qgis ...
> Preparing to replace python-qgis-common 1.4.0+12730-5ubuntu1 (using
> .../python-qgis-common_1.7.3-1~natty1_all.deb) ...
> so maybe there is something else wrong?
> Regards
> On 28 January 2012 21:46, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> A classic problem we really need to tackle better: you're missing the
>> python-qgis package or maybe the base plugins
>> sudo apt-get install python-qgis python-qgis-common
>> Give that a try, restart qgis and see if you have python plugin access.
>> Thanks,
>> Alex
>> On 01/28/2012 01:39 PM, Gerhardus Geldenhuis wrote:
>>> Thanks Alex,
>>> I only have "Manage Plugins" and "Python Console" on my Plugins menu and
>> my
>>> list of plugins does not contain qspatialite plugin. I am using 1.7.0 on
>>> Ubuntu. I am trying to get the spatialite gui working at the moment as
>> the
>>> alternative.
>>> Regards
>>>  http://www.gaia-gis.it
>>> On 28 January 2012 21:16, Alex Mandel <tech_dev at wildintellect.com>
>> wrote:
>>>> On 01/28/2012 01:08 PM, Gerhardus Geldenhuis wrote:
>>>>> Hi
>>>>> I have spend some time polishing the data I have and it is in csv
>>>> format. I
>>>>> would like to run queries on it and display a number of custom
>> queries's
>>>>> data on my map. I thought spatialite would be the answer but I am
>>>>> struggling to connect the dots. I first tried to import the csv file
>>>>> directly which worked a treat. I then exported the csv file as a SQLite
>>>>> database and tried to add it as Spatialite database, that failed for
>>>>> obvious reasons.
>>>>> I then thought that maybe I can directly do queries on the csv
>> data.... I
>>>>> managed to get a query working on the data and that query now displays
>>>>> different coloured dots. However I could not find this query again nor
>>>> seem
>>>>> to be able to change the symbology based on the query type.
>>>>> My csv file contain multiple types of points which I would like to map
>>>> with
>>>>> different symbology. Any help would be appreciated. The manual explains
>>>> how
>>>>> to create a spatialite db but makes no mention of how to get data into
>> a
>>>>> spatialite db,
>>>>> Any help would be greatly appreciated.
>>>>> Best Regards
>>>> Try the QSpatialite plugin (from Fetch python plugins).
>>>> 1. Create an empty spatial database
>>>> 2. Connect and use the Upload Tables tab under which you can pick CSV as
>>>> the source.
>>>> Alternative method, download the spatialite gui from spatialite website
>>>> and use that to import the csv. Once imported QGIS will be able to see
>>>> it, though you may need to create a geometry column and run an update
>>>> query to populate it.
>>>> Enjoy,
>>>> Alex
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120130/679c5b67/attachment.html>
