[Qgis-user] [PROPOSAL] From srs.db to file-based CRS storage
David Fawcett
david.fawcett at gmail.com
Mon Jan 30 13:00:15 PST 2012
If you wanted a true text file storage format, you could look at
proj.4. http://trac.osgeo.org/proj/
I know that MapServer, PostGIS, Grass, OGR, and other projects use it.
I don't know if the proj.4 data file would be useful to the
projection engine used by QGIS or not.
Maybe the real issue isn't the storage format, but instead, tools to
add (or remove) new spatial reference system definitions.
David.
On Mon, Jan 30, 2012 at 2:31 PM, Alexander Bruy
<alexander.bruy at gmail.com> wrote:
> Hi Andreas,
> 2012/1/30 Andreas Neumann <a.neumann at carto.net>:
>> srs.db is file-based already. You can easily edit and update it with any
>> sqlite compatible db application, such as sqliteman, openoffice, qgis,
>> firefox, etc.
> Working with sqlite requires SQL knowledge and database manager/editor,
> while moving and editing flat text files is much easier for ordinal users.
> Alexander Bruy
> Qgis-user mailing list
