[Qgis-user] [PROPOSAL] From srs.db to file-based CRS storage
Andreas Neumann
a.neumann at carto.net
Mon Jan 30 13:07:15 PST 2012
Well - in my opinion, if one really wants to edit CRS it would be best
to document the process well in the manual and leave the CRS storage as is.
1. - one doesn't need to edit the definitions very often
2. - one needs to do it very carefully. CRS definitions are far more
complex than SQL in my opinion. You really need to know what you do or
your data will end up corrupted.
3. - SQLite databases are very accessible. Even QGIS can be used to open
and edit the tables. SQLiteMan comes with every Linux distribution and
also as a firefox plugin.
4. - with SQLite, the data is at least structure. With text-based
formats you need to parse the format and you open doors for mistakes and
unstructured data.
5. - if definitions are missing, people should contribute them to the
project so others can use them as well.
Just my two cents.
Andreas
On 01/30/2012 09:31 PM, Alexander Bruy wrote:
> Hi Andreas,
> 2012/1/30 Andreas Neumann <a.neumann at carto.net>:
>> srs.db is file-based already. You can easily edit and update it with any
>> sqlite compatible db application, such as sqliteman, openoffice, qgis,
>> firefox, etc.
> Working with sqlite requires SQL knowledge and database manager/editor,
> while moving and editing flat text files is much easier for ordinal users.
