[Qgis-user] Autocreating a qix file
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Jun 1 04:54:07 PDT 2012
I have a process which creates a new shapefile on a regular basis which I
then provide to one of our users, however I'd like the new file to be
spatially indexed.
Is there a way to automatically generate a qix (QGIS shapefile index) file?
By which I mean one that doesn't require any manual intervention.
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120601/d32da4b5/attachment.html>
