[Qgis-user] Autocreating a qix file
David Fawcett david.fawcett at gmail.com
Fri Jun 1 06:27:52 PDT 2012
There is the shpTree Utility that comes with MapServer:
http://trac.osgeo.org/mapserver/wiki/ShpTree
David.
On Fri, Jun 1, 2012 at 6:54 AM, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> I have a process which creates a new shapefile on a regular basis which I
> then provide to one of our users, however I'd like the new file to be
> spatially indexed.
> Is there a way to automatically generate a qix (QGIS shapefile index)
> file? By which I mean one that doesn't require any manual intervention.
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120601/ce65363e/attachment.html>
