[Qgis-user] error in SAGA grid calculator
Victor Olaya
volayaf at gmail.com
Tue Jun 5 00:15:17 PDT 2012
stefano
Which version of SEXTANTE are you using? It seems that, when calling
SAGA; it is not adding the RESULT value, which does not happen in the
current version.
Regarding the resampling region, it is the same as the grid system,
but you do not have to worry about layers having the same grid system,
SEEXTANTE will take care of that and resample all input layer
automatically
Hope this helps
Regards
2012/6/5 skampus <stefano.campus at regione.piemonte.it>:
> hi to all,
> i can't find a solution of an error that is drivin' me mad.
> i'm trying to do a simple calculus by means of grid calculator of saga,
> contained in sextante.
> most of operations don't give me a result because an error tells me "could
> not to load layer" followed by the path of grid generated by calculator.
> please find attached log files of sextante.
> another question...
> i didn't understand the meanings of resampling region values in the
> configuration window of sextante-saga module.
> in saga gui, resampling is set by "grid system" that must be selected first
> of any operation among raster.
> so i thought that this is the way to indicate the reference for creating new
> layers (extension and cellsize).
> if it's so, i dont understand the relation between general configuration and
> "grid system"
> hope to be clear, sorry for my poor english
> ciao!
> http://osgeo-org.1560.n6.nabble.com/file/n4979103/sextante_qgis.log
> sextante_qgis.log
> View this message in context: http://osgeo-org.1560.n6.nabble.com/error-in-SAGA-grid-calculator-tp4979103.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
