[Qgis-user] Svar: Re: Qgis crashes frequently when digitizing streams over WMS images
Lene Fischer
lfi at life.ku.dk
Wed Jun 6 07:50:54 PDT 2012
Today I reached the same problem. In the middelof a lecture with 25
students 3 sessions crashed with no warnings.
I had the same lecture last week with no problems...
I tried to work with the data myself for 1 hour. 2 times it crashed
again, but without a significant reason.
We have been using WMS-layer and shape layer.
A the first pc, it started with polygons didn´t appear after filling
out the attributes.
Trying to save - a crash.
At the second pc : While digitizing and editing. After moving an object
and then digitizing it was impossible to save the layer.
We use Snapping Options to Vertex and Segments. This we didn´t use last
week at the first lessons.
Hope anyone can help.
Regards
Lene Fischer
Ass. Professor - GIS & GPS
Danish Center for Forest, Landscape and Planning
University of Copenhagen
Nødebovej 77A
DK- 3480 Fredensborg
Phone: 0045 40115084
Mail: LFI at LIFE.KU.DK
Skype: lene.fischer.dk
>>> Filipe Silva Dias <filipesdias at gmail.com> 21-05-2012 15:06 >>>
Hi Giovanni
I think you already did more than enough to try to help determine what
is wrong with (my) QGIS. If Im the only one getting these crashes then
its safe to assume that there's something wrong "on my end".
I keep getting them in two machines and I have made numerous attempts
to understand what the hell is wrong with this. Maybe it is some
specific configuration parameter of QGIS, I dont know.
Fortunately for me there are other FOSS softwares I can use to do what
I need and If I ever get rid of these crashes and find out what was
causing them I will make sure to tell you.
Thanks again for help and efforts
Cheers
On Mon, May 21, 2012 at 1:36 PM, Giovanni Manghi
<giovanni.manghi at faunalia.pt> wrote:
Hi Filipe,
> With tiff - on a new and clean project (opened, loaded .tiff and shp
> and started digitizing), this problem doesnt seem to occur, or at
> least is a lot less frequent.
> With WMS - it depends, sometimes I dont get any crashes for 2/3
hours,
> and on other occasions I get crash after crash.
> If indeed Im the only user affected by this, Ill switch to another
> software and be done with it.
Hi Filipe,
I don't have any particular interest in confirming or not a bug. In
this
case I cannot confirm. I tested your data for 20/30 minutes and didn't
get a crash. Last week I had to do a job that involved digitizing
(using
the same WMS layer you cite) and didn't get any crash in many hours of
work.
Does this mean that the issue is not confirmed? no... but as I tested
on
two OS including the one you use it is suspicious that can be a local
problem. The only thing that does not convince me is that you get the
crash on two different machines. Maybe the issue is caused by a
specific
QGIS configuration parameter?
Would you be able to test in Linux, so it will be possible to get the
eventual error message from the Linux console?
cheers
-- Giovanni --
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120606/32f59c2e/attachment.html>
