[Qgis-user] Wall Map
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Jun 7 23:20:14 PDT 2012
I am replying to the list, too.
You can edit the legend in the print layout itself (delete layers,
change fonts, change labels...) but not after printing to pdf. Maybe you
should give svg export a try (never did it myself, should do it one day)
and edit the result in incscape.
Bernhard
Am 07.06.2012 21:58, schrieb Chuck Young:
> Thanks! I kind of got started and the
> pDF does look good after creation. I Haven't figured how to get a
> legend on it which I can edit.
> On Thu, Jun 7, 2012 at 2:10 AM, Bernhard Ströbl
> <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>> wrote:
> Hi Charles,
> you set the physical size of your printout in the "composition" tag.
> Extent and scale of the map are set in the "Item Properties" when
> the map is activated. If you need a 1:1 scale of your printout,
> print into pdf and visualize with 100%. Especially text size is
> shown as e.g. 10pt in the print composer and thus seems to be too
> huge if you want to print large maps.
> hope this helps
> Bernhard
> Am 07.06.2012 10:17, schrieb Chuck Young:
> I want to print a wall map in the size of 8FT x 4FT. I am using a
> double 19 inch monitor setup and need to be able to select the
> entire
> area to be printed, and get it to come into the Print Composer
> with the
> correct zoom level. At present I get the same view as I get on
> my two
> monitor setup. I defined the map to be 4' x 8' and brought the
> current
> view into the print composer and get the same zoom as I see on the
> monitors.
> At this zoom I get the area I want but the details are so small
> it is
> useless.
> HELP!!!
> Thanks in advance
> Charles
> _________________________________________________
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/qgis-user
> <http://lists.osgeo.org/mailman/listinfo/qgis-user>
________ Information from NOD32 ________
This message was checked by NOD32 Antivirus System for Linux Mail Server.
http://www.nod32.com
