[Qgis-user] Wall Map
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Jun 7 02:10:05 PDT 2012
Hi Charles,
you set the physical size of your printout in the "composition" tag.
Extent and scale of the map are set in the "Item Properties" when the
map is activated. If you need a 1:1 scale of your printout, print into
pdf and visualize with 100%. Especially text size is shown as e.g. 10pt
in the print composer and thus seems to be too huge if you want to print
large maps.
hope this helps
Bernhard
Am 07.06.2012 10:17, schrieb Chuck Young:
> I want to print a wall map in the size of 8FT x 4FT. I am using a
> double 19 inch monitor setup and need to be able to select the entire
> area to be printed, and get it to come into the Print Composer with the
> correct zoom level. At present I get the same view as I get on my two
> monitor setup. I defined the map to be 4' x 8' and brought the current
> view into the print composer and get the same zoom as I see on the
> monitors.
> At this zoom I get the area I want but the details are so small it is
> useless.
> HELP!!!
> Thanks in advance
> Charles
> Qgis-user mailing list
________ Information from NOD32 ________
This message was checked by NOD32 Antivirus System for Linux Mail Server.
http://www.nod32.com
