[Qgis-user] default print template
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Jun 11 00:04:10 PDT 2012
in my organisation we use a default project with a couple of standard
layers already loaded. We used to have a bunch of default print
templates in there, too (A4/A3/A0 each portrait and landscape). It
turned out that the load time of the project was _a lot_ longer with the
print templates than without them.
Bernhard
Am 11.06.2012 01:04, schrieb Jake Maier:
>> -----Original Message-----
>> From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-
>> bounces at lists.osgeo.org] On Behalf Of Christine
>> Sent: Sunday, June 10, 2012 6:26 PM
>> To: qgis-user at lists.osgeo.org
>> Subject: Re: [Qgis-user] default print template
>> " ..., I don't want to each time I open the composer to load the
>> template, ..."
>> Well, if you create a new QGIS project, in the print composer you have
>> only to load a template (*.qgt) once. It will be saved with the project
>> file (*.qgs). Actually you can load and save several templates/map
>> compositions in the map composer of a QGIS project. You may also rename
>> or delete them, if you like.
>> There will never be a template that will satisfy the needs of all/many
>> users. A good idea could be creating a collection of templates for
>> different purposes, so users might choose and download their favorites
>> - similar like with the plugins.
>> Regards, Christine
>> View this message in context: http://osgeo-
>> org.1560.n6.nabble.com/default-print-template-tp4980191p4980257.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> [JM]
> That is a good work around and something I need to start much more to set up
> for my purposes.
> It's that little bit of extra work at the beginning (which nobody has time
> to do) which will save so much work in the long run.
> Again thanks Christine
> Jake
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
