[Qgis-user] default print template
Jake Maier
j.m at jmforestry.com
Sun Jun 10 16:04:24 PDT 2012
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-
> bounces at lists.osgeo.org] On Behalf Of Christine
> Sent: Sunday, June 10, 2012 6:26 PM
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] default print template
> " ..., I don't want to each time I open the composer to load the
> template, ..."
> Well, if you create a new QGIS project, in the print composer you have
> only to load a template (*.qgt) once. It will be saved with the project
> file (*.qgs). Actually you can load and save several templates/map
> compositions in the map composer of a QGIS project. You may also rename
> or delete them, if you like.
> There will never be a template that will satisfy the needs of all/many
> users. A good idea could be creating a collection of templates for
> different purposes, so users might choose and download their favorites
> - similar like with the plugins.
> Regards, Christine
> View this message in context: http://osgeo-
> org.1560.n6.nabble.com/default-print-template-tp4980191p4980257.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
[JM]
That is a good work around and something I need to start much more to set up
for my purposes.
It's that little bit of extra work at the beginning (which nobody has time
to do) which will save so much work in the long run.
Again thanks Christine
Jake
