[Qgis-user] default print template
Jake Maier j.m at jmforestry.com
Sun Jun 10 15:56:40 PDT 2012
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-
> bounces at lists.osgeo.org] On Behalf Of Etienne Tourigny
> Sent: Sunday, June 10, 2012 6:31 PM
> To: Christine
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] default print template
> Of course no defaults can satisfy all users completely.
> This, as well as personalized default styles, could be achieved if we
> could customize the "default" project.
> Basically, one could save a project as the default, which would get
> loaded every time a new project is created - instead of the global
> defaults.
> Makes sense?
> Etienne
> On Sun, Jun 10, 2012 at 7:26 PM, Christine <geo.guide at web.de> wrote:
> > " ...,  I don't want to each time I open the composer to load the
> > template, ..."
> > Well, if you create a new QGIS project, in the print composer you
> have
> > only to load a template (*.qgt) once. It will be saved with the
> > project file (*.qgs). Actually you can load and save several
> > templates/map compositions in the map composer of a QGIS project. You
> > may also rename or delete them, if you like.
> > There will never be a template that will satisfy the needs of
> all/many
> > users. A good idea could be creating a collection of templates for
> > different purposes, so users might choose and download their
> favorites
> > - similar like with the plugins.
> > Regards, Christine
> > View this message in context:
> > http://osgeo-org.1560.n6.nabble.com/default-print-template-
> tp4980191p4
> > 980257.html Sent from the Quantum GIS - User mailing list archive at
> > Nabble.com.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
[JM] Yes Etienne, that's exactly what I had in mind.
Tell qgis that this template should be loaded as the default at the
beginning of each program start.
Is there a way to have a python file loaded and executed as a default each
time the program starts?
I don't know much about python yet, but want to learn more about it and I'm
sure it can be programmed to do exactly that.
Jake
