[Qgis-user] default print template
    Etienne Tourigny
    etourigny.dev at gmail.com
    Sun Jun 10 15:30:52 PDT 2012
Of course no defaults can satisfy all users completely.
This, as well as personalized default styles, could be achieved if we
could customize the "default" project.
Basically, one could save a project as the default, which would get
loaded every time a new project is created - instead of the global
defaults.
Makes sense?
Etienne
On Sun, Jun 10, 2012 at 7:26 PM, Christine <geo.guide at web.de> wrote:
> " ...,  I don't want to each time I open the composer to load the template,
> Well, if you create a new QGIS project, in the print composer you have only
> to load a template (*.qgt) once. It will be saved with the project file
> (*.qgs). Actually you can load and save several templates/map compositions
> in the map composer of a QGIS project. You may also rename or delete them,
> if you like.
> There will never be a template that will satisfy the needs of all/many
> users. A good idea could be creating a collection of templates for different
> purposes, so users might choose and download their favorites - similar like
> with the plugins.
> Regards, Christine
> View this message in context: http://osgeo-org.1560.n6.nabble.com/default-print-template-tp4980191p4980257.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
