[Qgis-user] SPIT not seeing PostGres SQL Connections
Agustin Lobo alobolistas at gmail.com
Tue Jun 12 01:40:13 PDT 2012
Micha,
If I enter "postgres" as user in SPIT, I'm prompted
to enter the password. As user postgres was automatically
set up during the installation, was a password also set up
for it or should I set up one using the same procedure
than the one you indicated for user alobo ?
(things work out with SPIT using user alobo thanks to your directions, this is
just for completeness)
Thanks
Agus
2012/6/11 Agustin Lobo <alobolistas at gmail.com>:
> Micha,
> Just one question before I try: that password has to be the real
> password or can it be
> an specific password to be used by user alobo for postgres?
> Actually writing a password is very unsecure.
> Thanks
> Agus
> 2012/6/11 Micha Silver <micha at arava.co.il>:
>> On 06/11/2012 12:16 PM, Agustin Lobo wrote:
>> Hi!
>> I've followed (not without pain, see at the end) the example
>> of creating a PostGIS database in G.Sherman book
>> p. 113-121 on ubuntu 10.04.
>> Thus, I have created a database named geospatial_desktop.
>> Nevertheless, when I try to use SPIT to load the data,
>> geospatial_desktop is not listed (actually nothing is listed)
>> in the PostgSQL connections list.
>> Is there any place where I have to tell QGIS the path
>> of the databases?
>> Problems I mentioned:
>> 1. createdb -E UTF8 geospatial_desktop
>> resulted into
>> ident authentication failed for user "alobo"
>> which was solved by modifying /etc/postgresql/8.4/main/pg_hba.conf
>> according to
>> http://stackoverflow.com/questions/2942485/psql-fatal-ident-authentication-failed-for-user-postgres
>> 2. The same command produced a second error:
>> createdb: could not connect to database postgres: FATAL: role  "alobo"
>> does not exist
>> This was solved by running the commands preceded by sudo -i -u postgres,
>> i.e.
>> sudo -i -u postgres createdb -E UTF8 geospatial_desktop
>> as mentioned in
>> http://ubuntuforums.org/showthread.php?t=1515069
>> (actually, is it "normal" having to su to user postgres for using postgres?)
>> If this is a local-only database then what you might want to do is create a
>> second superuser with your username, and grant him all privileges. Then go
>> and re-edit the pg_hba.conf to allow this new user access from localhost,
>> and you should be good to go. So:
>> sudo -i -u postgres psql
>> postgres=# CREATE USER alobo WITH LOGIN SUPERUSER PASSWORD 'yourpassword';
>> postgres=# GRANT ALL PRIVILEGES ON geospatial_desktop.* TO alobo WITH GRANT
>> OPTION;
>> postgres=# \q
>> Now put another line into pg_hba.conf
>> host    all            alobo        127.0.0.1/32    trust
>> Restart postgresql and try, as alobo, to connect with psql. If that works
>> then pgAdmin3 and QGIS should be OK.
>> Micha
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> This mail was received via Mail-SeCure System.
