[Qgis-user] Problems with Rasterize Gdal Plugin
Etienne Tourigny
etourigny.dev at gmail.com
Wed Jun 13 09:22:26 PDT 2012
If you do "gdalinfo --formats" you will see which raster formats
support Create and Update (which gdal_rasterize and gdalwarp require)
- this is indicated by 'w+'
GTiff (rw+v): GeoTIFF
AAIGrid (rwv): Arc/Info ASCII Grid
--formats
List all raster formats supported by this GDAL build (read-only and
read-write) and exit. The format support is indicated as follows: 'ro'
is read-only driver; 'rw' is read or write (ie. supports CreateCopy);
'rw+' is read, write and update (ie. supports Create). A 'v' is
appended for formats supporting virtual IO (/vsimem, /vsigzip,
/vsizip, etc). Note: The valid formats for the output of gdalwarp are
formats that support the Create() method (marked as rw+), not just the
CreateCopy() method.
On Wed, Jun 13, 2012 at 1:10 PM, Giovanni Manghi
<giovanni.manghi at faunalia.pt> wrote:
>> What is the problem?
> I hit the same issue yesterday,
> apparently gdal rasterize does not support writing asc directly.
> Rasterize as tiff first and then use gdal translate to save as ASC.
> cheers
> -- Giovanni --
> Qgis-user mailing list
