[Qgis-user] Problems with Rasterize Gdal Plugin
Giovanni Manghi
giovanni.manghi at faunalia.pt
Wed Jun 13 09:29:28 PDT 2012
> - this is indicated by 'w+'
> GTiff (rw+v): GeoTIFF
> AAIGrid (rwv): Arc/Info ASCII Grid
but rasterize does not support anyway writing directly ASC. This is what
I get from
gdal_rasterize -a CODPRED -ts 3000 3000 -l pred pred.shp test.asc
Output driver `AAIGrid' not recognised or does not support
direct output file creation. The following format drivers are configured
and support direct output:
JP2ECW: ERDAS JPEG2000 (SDK 3.x)
VRT: Virtual Raster
GTiff: GeoTIFF
NITF: National Imagery Transmission Format
HFA: Erdas Imagine Images (.img)
ELAS: ELAS
MEM: In Memory Raster
BMP: MS Windows Device Independent Bitmap
PCIDSK: PCIDSK Database File
ILWIS: ILWIS Raster Map
SGI: SGI Image File Format 1.0
Leveller: Leveller heightfield
Terragen: Terragen heightfield
netCDF: Network Common Data Format
HDF4Image: HDF4 Dataset
ISIS2: USGS Astrogeology ISIS cube (Version 2)
ERS: ERMapper .ers Labelled
RMF: Raster Matrix Format
RST: Idrisi Raster A.1
INGR: Intergraph Raster
GSBG: Golden Software Binary Grid (.grd)
PNM: Portable Pixmap Format (netpbm)
ENVI: ENVI .hdr Labelled
EHdr: ESRI .hdr Labelled
PAux: PCI .aux Labelled
MFF: Vexcel MFF Raster
MFF2: Vexcel MFF2 (HKV) Raster
BT: VTP .bt (Binary Terrain) 1.3 Format
LAN: Erdas .LAN/.GIS
IDA: Image Data and Analysis
GTX: NOAA Vertical Datum .GTX
NTv2: NTv2 Datum Grid Shift
ADRG: ARC Digitized Raster Graphics
SAGA: SAGA GIS Binary Grid (.sdat)
