[Qgis-user] Problems with Rasterize Gdal Plugin
Etienne Tourigny etourigny.dev at gmail.com
Wed Jun 13 09:36:23 PDT 2012
On Wed, Jun 13, 2012 at 1:29 PM, Giovanni Manghi
<giovanni.manghi at faunalia.pt> wrote:
>> - this is indicated by 'w+'
>>   GTiff (rw+v): GeoTIFF
>>   AAIGrid (rwv): Arc/Info ASCII Grid
> but rasterize does not support anyway writing directly ASC. This is what
> I get from
AAIGrid is the driver for .asc files, and it does not support Create
(direct output file creation), it support CreateCopy only - see above
it only has (rwv), i't missing the '+'.
Therefore gdal_rasterize is not supported for asc files.
> gdal_rasterize -a CODPRED -ts 3000 3000 -l pred pred.shp test.asc
> Output driver `AAIGrid' not recognised or does not support
> direct output file creation. The following format drivers are configured
> and support direct output:
> JP2ECW: ERDAS JPEG2000 (SDK 3.x)
> VRT: Virtual Raster
> GTiff: GeoTIFF
> NITF: National Imagery Transmission Format
> HFA: Erdas Imagine Images (.img)
> ELAS: ELAS
> MEM: In Memory Raster
> BMP: MS Windows Device Independent Bitmap
> PCIDSK: PCIDSK Database File
> ILWIS: ILWIS Raster Map
> SGI: SGI Image File Format 1.0
> Leveller: Leveller heightfield
> Terragen: Terragen heightfield
> netCDF: Network Common Data Format
> HDF4Image: HDF4 Dataset
> ISIS2: USGS Astrogeology ISIS cube (Version 2)
> ERS: ERMapper .ers Labelled
> RMF: Raster Matrix Format
> RST: Idrisi Raster A.1
> INGR: Intergraph Raster
> GSBG: Golden Software Binary Grid (.grd)
> PNM: Portable Pixmap Format (netpbm)
> ENVI: ENVI .hdr Labelled
> EHdr: ESRI .hdr Labelled
> PAux: PCI .aux Labelled
> MFF: Vexcel MFF Raster
> MFF2: Vexcel MFF2 (HKV) Raster
> BT: VTP .bt (Binary Terrain) 1.3 Format
> LAN: Erdas .LAN/.GIS
> IDA: Image Data and Analysis
> GTX: NOAA Vertical Datum .GTX
> NTv2: NTv2 Datum Grid Shift
> ADRG: ARC Digitized Raster Graphics
> SAGA: SAGA GIS Binary Grid (.sdat)
