[Qgis-user] FW: Problem with Ubuntu 12
Etienne Tourigny
etourigny.dev at gmail.com
Thu Jun 14 07:40:55 PDT 2012
You are probably referring to my comment "in the kde case..." - that
was a phrase I started and forgot to remove...
When you install kubuntu, you will login to the KDE plasma desktop,
but nothing stops you from installing the ubuntu-desktop which will
give you the choice of running unity.
On Thu, Jun 14, 2012 at 11:31 AM, Brad Nesom <gisbradokla at live.com> wrote:
> and some of us may not even understand.
> I have kubuntu.
> Something said here seems to mean that is (KDE) unity?
> but don't understand if that is true.
> On Thu, Jun 14, 2012 at 8:25 AM, Etienne Tourigny <etourigny.dev at gmail.com>
> wrote:
>> Agreed - but many Unity users might not, so it should at least work as
>> expected...
>> Most newcomers to linux will most probably use Unity as it's the
>> default desktop of the most popular distro for first-time linux users
>> (I think).
>> Etienne
>> On Thu, Jun 14, 2012 at 10:10 AM, Agustin Lobo <alobolistas at gmail.com>
>> wrote:
>> > In my opinion, it's sufficient to state that qgis users should keep
>> > unity far away from them, which will be actually a good option for many
>> > other
>> > purposes. unitiy is not a good desktop and it would
>> > be a pity wasting a lot of grey brainware time on making qgis
>> > work well under unity. Enough grey brainware time is wasted already
>> > with windows...
>> > Agus
>> > 2012/6/13 Gerardo Jimenez <gejst5 at hotmail.com>:
>> >> After cheking in the ticket mentioned earlier, it does work with unity,
>> >> partially. At first it does not display nothing, unless you reclick on
>> >> the
>> >> qgis button. On unity 2d, gnome classic and gnome with no efects qgis
>> >> works
>> >> ok
>> >> Gerardo Jiménez Delgado
>> >> Instituto de Investigaciones Antropológicas
>> >> Universidad Nacional Autónoma de México
>> >> Ciudad Universitaria s/n
>> >> Coyoacan 04510 Mexico City
>> >> Mexico 56 22 95 16
>> >>> Subject: Re: [Qgis-user] FW: Problem with Ubuntu 12
>> >>> From: giovanni.manghi at faunalia.pt
>> >>> To: etourigny.dev at gmail.com
>> >>> CC: gejst5 at hotmail.com; qgis-user at lists.osgeo.org
>> >>> Date: Wed, 13 Jun 2012 17:07:18 +0100
>> >>> > That's weird - should probably be filed as a bug... You are talking
>> >>> > about the dev version or 1.7, or both?
>> >>> I filed a ticket months ago. Don't remember about 1.7.4, but it
>> >>> happens
>> >>> for sure with 1.8
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
