[Qgis-user] QGIS webclient search
Dennis Ströer
dennis.stroeer at geosysnet.de
Thu Jun 14 07:41:18 PDT 2012
Hello everybody,
I'm doing some tests with QGIS Webclient, too. Now, I have the same
problems like Nelson before. Have you or anybody else meanwhile found a
solution for this problem or a adequate example?
Cheers,
D. Stroeer
>Hello QGIS user,
>I'm doing some tests with QGIS server/webclient and now i try to
configure the search option with
>the configuration mentioned here
https://github.com/qgis/qgis-web-client/blob/master/readme.txt
>After create the search table in PostgreSQL, i try to make some search
in the webclient, but it
>not return any values.
>So i have a configuration problem any where, but i dont now where.
>I presume, that the table must be created in the Schema that have the
geographic data. Yes?
>If can one have a little example to see how it works, i will appreciate.
>Best Regards,
>Nelson
