[Qgis-user] QGIS webclient search
Bernhard Ströbl bernhard.stroebl at jena.de
Thu Jun 14 22:42:31 PDT 2012
Hi Dennis,
do I understand right, that you want to use the wsgi search scripts?
Does the script return anything when you enter it directly in your
browser? Any database error should be logged to your apache log file (or
QGIS webclient log file), e.g. if you cannot connect to your DB. Any
errors in the Query should also be logged in your DB server's log.
hope this helps
Bernhard
Am 14.06.2012 16:41, schrieb Dennis Ströer:
> Hello everybody,
> I'm doing some tests with QGIS Webclient, too. Now, I have the same
> problems like Nelson before. Have you or anybody else meanwhile found a
> solution for this problem or a adequate example?
> Cheers,
> D. Stroeer
>  >Hello QGIS user,
>  >I'm doing some tests with QGIS server/webclient and now i try to
> configure the search option with
>  >the configuration mentioned here
> https://github.com/qgis/qgis-web-client/blob/master/readme.txt
>  >After create the search table in PostgreSQL, i try to make some search
> in the webclient, but it
>  >not return any values.
>  >So i have a configuration problem any where, but i dont now where.
>  >I presume, that the table must be created in the Schema that have the
> geographic data. Yes?
>  >If can one have a little example to see how it works, i will appreciate.
>  >Best Regards,
>  >Nelson
> Qgis-user mailing list
________ Information from NOD32 ________
This message was checked by NOD32 Antivirus System for Linux Mail Server.
http://www.nod32.com
