[Qgis-user] ERROR - "The procedure entry point sqlite3_open_v2 could not be located in the dynamic link library sqlite3.dll" when running QGIS 1.7 and 1.8 after OSGEO4w installation
Filipe Silva Dias
filipesdias at gmail.com
Sat Jun 16 02:38:54 PDT 2012
I tried installing QGIS via "QGIS-OSGeo4W-1.7.4-d211b16-Setup.exe" and it
works.
I only get the message with QGIS installed from osgeo4w
On Sat, Jun 16, 2012 at 9:54 AM, Filipe Silva Dias <filipesdias at gmail.com>wrote:
> Hi Giuseppe
> I removed it (despite the installer complaining about dependencies), run
> QGIS again and got the same error. What else can I try?
> This had never happened. I just reinstalled Windows 7 and I didnt install
> any software that I didnt have before.
> I have some important things to do with QGIS and Im getting quite
> worried...
> Thanks
> On Fri, Jun 15, 2012 at 11:54 PM, Giuseppe Sucameli <brush.tyler at gmail.com
> > wrote:
>> Hi Filipe,
>> On Fri, Jun 15, 2012 at 6:59 PM, Filipe Silva Dias
>> <filipesdias at gmail.com> wrote:
>> > Reinstalling didnt work.
>> > I also tried deleting c./osgeo4w and reinstalling everything again and
>> that
>> > also didnt solve the problem
>> maybe you have another sqlite3 lib in your system which hides the one
>> shipped with osgeo4w.
>> Try to remove the sqlite3 lib from the osgeo4w installation and then run
>> QGis again. If the error persists then it's using a wrong sqlite3 lib.
>> Regards.
>> > On Fri, Jun 15, 2012 at 6:50 PM, Julian Bogdani <jbogdani at gmail.com>
>> wrote:
>> >> I have not a win now; sqlite3 should be the lib.
>> >> I did not downgrade the lib, just reinstalled it.
>> >> Julian Bogdani
>> >> http://bradypus.net
>> >> On 15 Jun 2012, at 19:47 , Filipe Silva Dias wrote:
>> >> Do you mean Libs->sqlite3 ? I tried reinstalling and going back to the
>> >> previous version but it didnt solve the problem.
>> >> Thks
>> >> On Fri, Jun 15, 2012 at 6:32 PM, Julian Bogdani <jbogdani at gmail.com>
>> >> wrote:
>> >>> I had the same problem in win 7.
>> >>> Telling osgeo4w to reinstall sqlite lib (osgeo4w, advanced mode)
>> solved
>> >>> my problem.
>> >>> Hope this helps
>> >>> Julian Bogdani
>> >>> http://bradypus.net
>> >>> On 15 Jun 2012, at 19:29 , Filipe Silva Dias wrote:
>> >>> Dear all
>> >>> I reinstalled QGIS today via osgeo4w and now I get this error when I
>> run
>> >>> QGIS 1.7 and 1.8
>> >>> Best
>> >>> F.
>> >>> _______________________________________________
>> >>> Qgis-user mailing list
>> >>> Qgis-user at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120616/fb53433a/attachment.html>
