[Qgis-user] ERROR - "The procedure entry point sqlite3_open_v2 could not be located in the dynamic link library sqlite3.dll" when running QGIS 1.7 and 1.8 after OSGEO4w installation
Ramon AndiƱach
custard at westnet.com.au
Sat Jun 16 03:00:31 PDT 2012
I'd have probably gone the other way around.
The one supplied with windows is now a bit old.
Either way. The error message is that QGIS can find more than one copy of the sqlite3.dll, and they're different versions - so its (understandably) confused and doesn't know which one to use.
For example see:
http://lists.osgeo.org/pipermail/qgis-user/2012-March/016296.html
and various other points in the mailing list.
-ramon.
On 16/06/2012, at 16:54 , Filipe Silva Dias wrote:
> Hi Giuseppe
> I removed it (despite the installer complaining about dependencies), run QGIS again and got the same error. What else can I try?
> This had never happened. I just reinstalled Windows 7 and I didnt install any software that I didnt have before.
> I have some important things to do with QGIS and Im getting quite worried...
> Thanks
> On Fri, Jun 15, 2012 at 11:54 PM, Giuseppe Sucameli <brush.tyler at gmail.com> wrote:
> Hi Filipe,
> On Fri, Jun 15, 2012 at 6:59 PM, Filipe Silva Dias
> <filipesdias at gmail.com> wrote:
> > Reinstalling didnt work.
> > I also tried deleting c./osgeo4w and reinstalling everything again and that
> > also didnt solve the problem
> maybe you have another sqlite3 lib in your system which hides the one
> shipped with osgeo4w.
> Try to remove the sqlite3 lib from the osgeo4w installation and then run
> QGis again. If the error persists then it's using a wrong sqlite3 lib.
> Regards.
> > On Fri, Jun 15, 2012 at 6:50 PM, Julian Bogdani <jbogdani at gmail.com> wrote:
> >> I have not a win now; sqlite3 should be the lib.
> >> I did not downgrade the lib, just reinstalled it.
> >> Julian Bogdani
> >> http://bradypus.net
> >> On 15 Jun 2012, at 19:47 , Filipe Silva Dias wrote:
> >> Do you mean Libs->sqlite3 ? I tried reinstalling and going back to the
> >> previous version but it didnt solve the problem.
> >> Thks
> >> On Fri, Jun 15, 2012 at 6:32 PM, Julian Bogdani <jbogdani at gmail.com>
> >> wrote:
> >>> I had the same problem in win 7.
> >>> Telling osgeo4w to reinstall sqlite lib (osgeo4w, advanced mode) solved
> >>> my problem.
> >>> Hope this helps
> >>> Julian Bogdani
> >>> http://bradypus.net
> >>> On 15 Jun 2012, at 19:29 , Filipe Silva Dias wrote:
> >>> Dear all
> >>> I reinstalled QGIS today via osgeo4w and now I get this error when I run
> >>> QGIS 1.7 and 1.8
> >>> Best
> >>> F.
