[Qgis-user] ERROR - "The procedure entry point sqlite3_open_v2 could not be located in the dynamic link library sqlite3.dll" when running QGIS 1.7 and 1.8 after OSGEO4w installation
Filipe Silva Dias
filipesdias at gmail.com
Sat Jun 16 03:11:55 PDT 2012
Ok, I was able to solve this by renaming "sqlite3.dll" to "sqlite31.dll"
located in:
C:\Windows\SysWOW64
Thanks for your help
Regards
On Sat, Jun 16, 2012 at 11:00 AM, Ramon AndiƱach <custard at westnet.com.au>wrote:
> I'd have probably gone the other way around.
> The one supplied with windows is now a bit old.
> Either way. The error message is that QGIS can find more than one copy of
> the sqlite3.dll, and they're different versions - so its (understandably)
> confused and doesn't know which one to use.
> For example see:
> http://lists.osgeo.org/pipermail/qgis-user/2012-March/016296.html
> and various other points in the mailing list.
> -ramon.
> On 16/06/2012, at 16:54 , Filipe Silva Dias wrote:
> > Hi Giuseppe
> > I removed it (despite the installer complaining about dependencies), run
> QGIS again and got the same error. What else can I try?
> > This had never happened. I just reinstalled Windows 7 and I didnt
> install any software that I didnt have before.
> > I have some important things to do with QGIS and Im getting quite
> worried...
> > Thanks
> > On Fri, Jun 15, 2012 at 11:54 PM, Giuseppe Sucameli <
> brush.tyler at gmail.com> wrote:
> > Hi Filipe,
> > On Fri, Jun 15, 2012 at 6:59 PM, Filipe Silva Dias
> > <filipesdias at gmail.com> wrote:
> > > Reinstalling didnt work.
> > > I also tried deleting c./osgeo4w and reinstalling everything again and
> that
> > > also didnt solve the problem
> > maybe you have another sqlite3 lib in your system which hides the one
> > shipped with osgeo4w.
> > Try to remove the sqlite3 lib from the osgeo4w installation and then run
> > QGis again. If the error persists then it's using a wrong sqlite3 lib.
> > Regards.
> > > On Fri, Jun 15, 2012 at 6:50 PM, Julian Bogdani <jbogdani at gmail.com>
> wrote:
> > >> I have not a win now; sqlite3 should be the lib.
> > >> I did not downgrade the lib, just reinstalled it.
> > >> Julian Bogdani
> > >> http://bradypus.net
> > >> On 15 Jun 2012, at 19:47 , Filipe Silva Dias wrote:
> > >> Do you mean Libs->sqlite3 ? I tried reinstalling and going back to the
> > >> previous version but it didnt solve the problem.
> > >> Thks
> > >> On Fri, Jun 15, 2012 at 6:32 PM, Julian Bogdani <jbogdani at gmail.com>
> > >> wrote:
> > >>> I had the same problem in win 7.
> > >>> Telling osgeo4w to reinstall sqlite lib (osgeo4w, advanced mode)
> solved
> > >>> my problem.
> > >>> Hope this helps
> > >>> Julian Bogdani
> > >>> http://bradypus.net
> > >>> On 15 Jun 2012, at 19:29 , Filipe Silva Dias wrote:
> > >>> Dear all
> > >>> I reinstalled QGIS today via osgeo4w and now I get this error when I
> run
> > >>> QGIS 1.7 and 1.8
> > >>> Best
> > >>> F.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120616/4ef0e1b7/attachment.html>
