[Qgis-user] QGIS Master and Rasters to grayscale
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Jun 19 02:48:37 PDT 2012
shows what happens when I use the method detailed below.
Is it a raster with integer values (but without color table)? In that
case, switch the renderer type to singleband pseudo color and insert the
color for each value.
Marco
Am 19.06.2012 11:18, schrieb James Stott:
> I have included links to two example jpgs to show what happens.
> 1.9.jpg shows what happens when I use the method detailed below.
> I would like the raster to display as in the 1.8 jpg.
> QGIS 1.8 https://docs.google.com/open?id=0B6r5nAOdEBZrSjhyaHdoUW9LY0U
> QGIS 1.9 https://docs.google.com/open?id=0B6r5nAOdEBZrLUJ1dDNNM3BJZVE
> *James Stott* BSc (Hons) MSc | Senior Professional
> *Nicholas Pearson Associates * | 30 Brock Street | Bath | BA1 2LN
> *T:* 01225 445548 | *M:* -
> *www.npaconsult.co.uk* <http://www.npaconsult.co.uk/>
> *From:*qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Marco
> Hugentobler
> *Sent:* 19 June 2012 09:49
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] QGIS Master and Rasters to grayscale
> Hi James
> You may go to the raster properties, select render type singleband
> gray. Then select contrast enhancement 'stretch to min/max' and click
> on 'load' to get the min/max values from the datasource.
> Having this by default (options page) is not yet available with the
> new raster classes. A bugticket is already filled.
> Regards,
> Marco
> Am 19.06.2012 10:17, schrieb James Stott:
> I sometimes display my Ordnance Survey rasters as single band gray to
> allow my data to show more clearly over the top of it.
> In the new master I cannot achieve the same effect. My raster goes
> solid grey.
> Old settings:
> Render as: Single Band gray
> Single band properties – gray band: Band 1
> Single band properties – color map: grayscale
> New settings:
> Render type: Singleband gray
> Gray band: Palette
> Contrast enhancement: No enhancement
> How do I achieve the same effect as before? The raster displays fine
> in colour, just not in grayscale. I am guessing it’s down to the new
> raster properties in master.
> *James Stott*BSc (Hons) MSc| Senior Professional
> *Nicholas Pearson Associates *| 30 Brock Street | Bath | BA1 2LN
> Nicholas Pearson Associates, Logo
> <http://www.npaconsult.co.uk/>Nicholas Pearson Associates, Latest News
> <http://www.npaconsult.co.uk/about-news.asp>
> Information and Registered Address
> <http://www.npaconsult.co.uk/terms.asp>
> This Electronic Transmission is intended only for the attention of the
> addressee. It may contain privileged and confidential information. If
> you are not the person for whom it is intended, you must not copy,
> distribute or take any action in reliance on it. If you have received
> this electronic transmission in error please notify us immediately by
> telephone, delete the transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure
> that this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44
> (0) 01225 445548, Fax: +44 (0) 01225 312387, Website:
> http://www.npaconsult.co.uk <http://www.npaconsult.co.uk/>
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Dr. Marco Hugentobler
> Sourcepole - Linux& Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch <mailto:marco.hugentobler at sourcepole.ch> http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120619/ce4028df/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120619/ce4028df/attachment.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120619/ce4028df/attachment-0001.jpe>
