[Qgis-user] QGIS Master and Rasters to grayscale
James Stott James.Stott at npaconsult.co.uk
Tue Jun 19 02:18:07 PDT 2012
I have included links to two example jpgs to show what happens. 1.9.jpg shows what happens when I use the method detailed below.
I would like the raster to display as in the 1.8 jpg.
QGIS 1.8 https://docs.google.com/open?id=0B6r5nAOdEBZrSjhyaHdoUW9LY0U
QGIS 1.9 https://docs.google.com/open?id=0B6r5nAOdEBZrLUJ1dDNNM3BJZVE
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Marco Hugentobler
Sent: 19 June 2012 09:49
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS Master and Rasters to grayscale
Hi James
You may go to the raster properties, select render type singleband gray. Then select contrast enhancement 'stretch to min/max' and click on 'load' to get the min/max values from the datasource.
Having this by default (options page) is not yet available with the new raster classes. A bugticket is already filled.
Regards,
Marco
Am 19.06.2012 10:17, schrieb James Stott:
I sometimes display my Ordnance Survey rasters  as single band gray to allow my data to show more clearly over the top of it.
In the new master I cannot achieve the same effect. My raster goes solid grey.
Old settings:
Render as: Single Band gray
Single band properties - gray band: Band 1
Single band properties - color map: grayscale
New settings:
Render type: Singleband gray
Gray band: Palette
Contrast enhancement: No enhancement
How do I achieve the same effect as before? The raster displays fine in colour, just not in grayscale. I am guessing it's down to the new raster properties in master.
James Stott BSc (Hons) MSc | Senior Professional
Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
T: 01225 445548 | M: -
www.npaconsult.co.uk <http://www.npaconsult.co.uk/>
  <http://www.npaconsult.co.uk/>   <http://www.npaconsult.co.uk/about-news.asp>
Information and Registered Address <http://www.npaconsult.co.uk/terms.asp>
This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website: http://www.npaconsult.co.uk <http://www.npaconsult.co.uk/>
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120619/d7444eb4/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120619/d7444eb4/attachment.jpg>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120619/d7444eb4/attachment-0001.jpg>
