[Qgis-user] Importing data from Google Earth into Postgis db in	QGIS
    Matt Boyd
    mattslists at gmail.com
    Tue Jun 19 04:43:48 PDT 2012
On Tue, Jun 19, 2012 at 5:09 PM, . <digitalmaps at cox.net> wrote:
> On 6/19/2012 1:32 AM, Paolo Cavallini wrote:
> Il 19/06/2012 04:47, . ha scritto:
> I've created some paths in Google Earth and I want to import to QGIS. So, I
> save as
> kml, then import vector layer, then save as shapefile. I create my database,
> connect,
> open PostGIS Manager and import data from shapefile.
> All goes well. I edit data and can't save it. Error message:
> ERROR: new row for relation "myfile" violates check constraint
> "enforce_dims_the_geom"
> Can someone walk me through getting my Google Earth data into a postgis
> database
> properly?
> Please wait a few days to install the new QGIS 1.8, try again with DB
> Manager, and
> report back.
> Thanks.
> I figured out the problem.
What was it?
I wish somebody would update Google Layers
> plugin. OpenLayers is slow, unwieldly and can't zoom in far enough for my
> needs. I'm satisfied with Google Layers.
I don't think the resolution on the google layers would be any better
than openlayers as it's all from the same place. When I need to work
offline or "zoom" in a little closer I use the "save as image" option
which saves a screenshot with a worldfile/georefernce information so
it can be added as a raster.
