[Qgis-user] QGIS Master and Rasters to grayscale
    James Stott
    James.Stott at npaconsult.co.uk
    Tue Jun 19 06:22:25 PDT 2012
> You can still do that by selecting "singleband gray", and choose the default contrast enhancement in the options.
This just turns the raster into 1 gray colour: 127, 127, 127
> can you share a bit sample of your raster?
Technically I don’t think I supposed to share the data as it is Ordnance Survey data.
I have included the metadata below if this helps:
Driver:
GDAL provider
VRT
Virtual Raster
Dataset Description
N:\Projects\10499 BP\Reference\Base Mapping\Raster\10000\OS 10000.vrt
Band 1
STATISTICS_MAXIMUM=9
STATISTICS_MEAN=3.2746921074487
STATISTICS_MINIMUM=0
STATISTICS_STDDEV=3.9133672791329
Dimensions:
X: 39370 Y: 31496 Bands: 1
Origin:
385000,95000
Pixel Size:
0.635001,-0.635001
No Data Value
-32768
Data Type:
GDT_Byte - Eight bit unsigned integer
Pyramid overviews:
Layer Spatial Reference System:
+proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000 +y_0=-100000 +ellps=airy +towgs84=375,-111,431,0,0,0,0 +units=m +no_defs
Layer Extent (layer original source projection):
385000.0000000000000000,75000.0000000000000000 : 410000.0000000000000000,95000.0000000000000000
Band
Band 1
Band No
1
No Stats
No stats collected yet
James Stott BSc (Hons) MSc | Senior Professional
Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
T: 01225 445548 | M: -
http://www.npaconsult.co.uk/
http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Salvatore Larosa
Sent: 19 June 2012 13:02
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS Master and Rasters to grayscale
Il giorno mar, 19/06/2012 alle 12.42 +0100, James Stott ha scritto:
> This does make what was a very simple thing to do in 1.8 more time
> consuming in 1.9 doesn’t it? All I want to do is just turn it
> grayscale for display purposes. In 1.8, all I do is select grayscale
> from the colormap drop down and push OK and QGIS does it for me. Am I
> missing something?
Hi James,
Regards,
-SL
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
http://www.npaconsult.co.uk/terms.asp
This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website: http://www.npaconsult.co.uk/
