[Qgis-user] QGIS Master and Rasters to grayscale
    Etienne Tourigny
    etourigny.dev at gmail.com
    Tue Jun 19 06:32:36 PDT 2012
DId you click on "Load" Button?
On Tue, Jun 19, 2012 at 10:22 AM, James Stott
<James.Stott at npaconsult.co.uk> wrote:
>> You can still do that by selecting "singleband gray", and choose the default contrast enhancement in the options.
> This just turns the raster into 1 gray colour: 127, 127, 127
>> can you share a bit sample of your raster?
> Technically I don’t think I supposed to share the data as it is Ordnance Survey data.
> I have included the metadata below if this helps:
> Driver:
> GDAL provider
> VRT
> Virtual Raster
> Dataset Description
> N:\Projects\10499 BP\Reference\Base Mapping\Raster\10000\OS 10000.vrt
> Band 1
> STATISTICS_MAXIMUM=9
> STATISTICS_MEAN=3.2746921074487
> STATISTICS_MINIMUM=0
> STATISTICS_STDDEV=3.9133672791329
> Dimensions:
> X: 39370 Y: 31496 Bands: 1
> Origin:
> 385000,95000
> Pixel Size:
> 0.635001,-0.635001
> No Data Value
> -32768
> Data Type:
> GDT_Byte - Eight bit unsigned integer
> Pyramid overviews:
> Layer Spatial Reference System:
> +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000 +y_0=-100000 +ellps=airy +towgs84=375,-111,431,0,0,0,0 +units=m +no_defs
> Layer Extent (layer original source projection):
> 385000.0000000000000000,75000.0000000000000000 : 410000.0000000000000000,95000.0000000000000000
> Band
> Band 1
> Band No
> 1
> No Stats
> No stats collected yet
> James Stott BSc (Hons) MSc | Senior Professional
> Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
> T: 01225 445548 | M: -
> http://www.npaconsult.co.uk/
> http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
> From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Salvatore Larosa
> Sent: 19 June 2012 13:02
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] QGIS Master and Rasters to grayscale
> Il giorno mar, 19/06/2012 alle 12.42 +0100, James Stott ha scritto:
>> This does make what was a very simple thing to do in 1.8 more time
>> consuming in 1.9 doesn’t it? All I want to do is just turn it
>> grayscale for display purposes. In 1.8, all I do is select grayscale
>> from the colormap drop down and push OK and QGIS does it for me. Am I
>> missing something?
> Hi James,
> Regards,
> -SL
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
> Qgis-user mailing list
> http://www.npaconsult.co.uk/terms.asp
> This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website: http://www.npaconsult.co.uk/
