[Qgis-user] DXF file & geometry
Andreas Neumann a.neumann at carto.net
Wed Jun 20 04:15:58 PDT 2012
 Unfortunately there is not proper DXF support currently for reading DXF
 files. QGIS only allows one geometry type per data source. The OGR dxf
 driver delivers multiple geometry types. QGIS just picks the first one
 that OGR delivers (could be point, lines and polygons). There needs to
 be some work done regarding the geometry types and the styling.
 For writing dxf it is actually better - but exporting styles is also
 not possible currently.
 Sorry that I don't have better news,
 Andreas
 On Tue, 19 Jun 2012 13:16:14 -0500, Brad Nesom wrote:
> that is probably the insert (anchor?), the centroid, label point, and
> the line list that make up the polygons.
> On Tue, Jun 19, 2012 at 6:01 AM, Philippe de FRANCLIEU  wrote:
>> Hi,
>> The geometry of a DXF file (french PCI-DXF) is defined as Polygon
>> in the metadata.
>> There are points and lines though. Which do not display...
>> Any hint? Should points and lines be extracted  to new files?
>> Regards.
>> p.s. : using QGIS 1.7.3 / W7
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org [1]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
> Links:
> [1] mailto:Qgis-user at lists.osgeo.org
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [3] mailto:pf at parcellesetpolygones.fr
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
