[Qgis-user] DXF file & geometry
Zirneklitis
eko at lanet.lv
Wed Jun 20 08:43:48 PDT 2012
You can use command line tool ogr2ogr, e.g.:
$ ogr2ogr -where "OGR_GEOMETRY='POINT'" -f "ESRI Shapefile"
my_out_file_points.shp my_in_file.dxf
OGR_GEOMETRY could be POINT, MULTIPOINT, LINESTRING, MULTILINESTRING,
POLYGON, MULTIPOLYGON.
Reference:
http://www.gdal.org/ogr/ogr_sql.html
Best regards,
Karlis
Andreas Neumann wrote:
> Unfortunately there is not proper DXF support currently for reading DXF
> files. QGIS only allows one geometry type per data source. The OGR dxf
> driver delivers multiple geometry types. QGIS just picks the first one
> that OGR delivers (could be point, lines and polygons). There needs to
> be some work done regarding the geometry types and the styling.
>> On Tue, Jun 19, 2012 at 6:01 AM, Philippe de FRANCLIEU wrote:
>>> The geometry of a DXF file (french PCI-DXF) is defined as Polygon
>>> in the metadata.
>>> There are points and lines though. Which do not display...
>>> Any hint? Should points and lines be extracted to new files?
