[Qgis-user] QGIS-1.8.0 Build Problem
    Harry G McGavran Jr
    w5pny at w5pny.com
    Thu Jun 21 09:03:33 PDT 2012
With the announcement of the release of QGIS-1.8.0, I'm trying to build
QGIS-1.8.0 on Ubuntu Lucid 10.04.  The configure worked fine, and the
build proceeded to:
[ 40%] Building CXX object
src/providers/postgres/CMakeFiles/postgresprovider.dir/moc_qgspgtablemodel.cxx.o
src/providers/postgres/CMakeFiles/postgresprovider.dir/moc_qgscolumntypethread.cxx.o
Linking CXX shared module
../../../output/lib/qgis/plugins/libpostgresprovider.so
[ 40%] Built target postgresprovider
[ 40%] Generating moc_qgsspatialiteconnection.cxx
[ 40%] Generating moc_qgsspatialiteprovider.cxx
[ 40%] Generating moc_qgsspatialitedataitems.cxx
[ 40%] Generating moc_qgsspatialitesourceselect.cxx
[ 40%] Generating moc_qgsspatialitetablemodel.cxx
Scanning dependencies of target spatialiteprovider
src/providers/spatialite/CMakeFiles/spatialiteprovider.dir/qgsspatialiteprovider.cpp.o
/usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:
In member function 'void
QgsSpatiaLiteProvider::convertFromGeosWKB2D(const unsigned char*,
size_t, unsigned char*, size_t, int, int, int)':
/usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1294:
error: 'GAIA_POINTZM' was not declared in this scope
/usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1297:
error: '
GAIA_POINTZ' was not declared in this scope
/usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1300:
error: 'GAIA_POINTM' was not declared in this scope
/usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1311:
error: 'GAIA_LINESTRINGZM' was not declared in this scope
/usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1314:
error: 'GAIA_LINESTRINGZ' was not declared in this scope
/usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1317:
error: 'GAIA_LINESTRINGM' was not declared in this scope
/usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1328:
error: 'GAIA_POLYGONZM' was not declared in this scope
/gaiageo.hp:1331: error: 'GAIA_POLYGONZ' was not declared in this scope
/qgsspatialiteprovider.cpp:1334: error: 'GAIA_POLYGONM' was not declared
in this scope
Lot's more of these follow.
These things are defined in
./src/core/spatialite/headers/spatialite/gaiageo.h
locally...
Suggestions???
Harry G. McGavran, Jr.
E-mail: w5pny at w5pny.com
