[Qgis-user] QGIS-1.8.0 Build Problem
Harry G McGavran Jr
w5pny at w5pny.com
Fri Jun 22 06:07:45 PDT 2012
I was later able to get this to build by including
"WITH_INTERNAL_SPATIALITE" during cmake.
When cmake runs, it has "WITH_INTERNAL_SPATIALITE" OFF and
"WITH_SPATIALITE" ON.
I have the spatialite package, so this seemed right and just
doing make after cmake finished with it's list of defaults
results in this problem. I had to turn ON
"WITH_INTERNAL_SPATIALITE" to get the build to work, even though
I have the spatialite package already installed.
On 06/21/12 10:03, Harry G McGavran Jr wrote:
> With the announcement of the release of QGIS-1.8.0, I'm trying to build
> QGIS-1.8.0 on Ubuntu Lucid 10.04. The configure worked fine, and the
> build proceeded to:
> [ 40%] Building CXX object
> src/providers/postgres/CMakeFiles/postgresprovider.dir/moc_qgspgtablemodel.cxx.o
> src/providers/postgres/CMakeFiles/postgresprovider.dir/moc_qgscolumntypethread.cxx.o
> Linking CXX shared module
> ../../../output/lib/qgis/plugins/libpostgresprovider.so
> [ 40%] Built target postgresprovider
> [ 40%] Generating moc_qgsspatialiteconnection.cxx
> [ 40%] Generating moc_qgsspatialiteprovider.cxx
> [ 40%] Generating moc_qgsspatialitedataitems.cxx
> [ 40%] Generating moc_qgsspatialitesourceselect.cxx
> [ 40%] Generating moc_qgsspatialitetablemodel.cxx
> Scanning dependencies of target spatialiteprovider
> src/providers/spatialite/CMakeFiles/spatialiteprovider.dir/qgsspatialiteprovider.cpp.o
> /usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:
> In member function 'void
> QgsSpatiaLiteProvider::convertFromGeosWKB2D(const unsigned char*,
> size_t, unsigned char*, size_t, int, int, int)':
> /usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1294:
> error: 'GAIA_POINTZM' was not declared in this scope
> /usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1297:
> error: '
> GAIA_POINTZ' was not declared in this scope
> /usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1300:
> error: 'GAIA_POINTM' was not declared in this scope
> /usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1311:
> error: 'GAIA_LINESTRINGZM' was not declared in this scope
> /usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1314:
> error: 'GAIA_LINESTRINGZ' was not declared in this scope
> /usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1317:
> error: 'GAIA_LINESTRINGM' was not declared in this scope
> /usr/local/src/qgis/qgis-1.8.0/src/providers/spatialite/qgsspatialiteprovider.cpp:1328:
> error: 'GAIA_POLYGONZM' was not declared in this scope
> /gaiageo.hp:1331: error: 'GAIA_POLYGONZ' was not declared in this scope
> /qgsspatialiteprovider.cpp:1334: error: 'GAIA_POLYGONM' was not declared
> in this scope
> Lot's more of these follow.
> These things are defined in
> ./src/core/spatialite/headers/spatialite/gaiageo.h
> locally...
> Suggestions???
Harry G. McGavran, Jr.
E-mail: w5pny at w5pny.com
