[Qgis-user] Invalid geometry
Sergio A Estay
sergio.estay at uach.cl
Fri Jun 22 07:37:27 PDT 2012
Hi Everybody and Ramon,
From the last actualization from QGIS 1.7.4 to 1.8.0 all my shp files
have "invalid geometry". For that reason now I can't make intersection
between vector layers. Previous to the actualization everything works
fine (using the same vector files).
As a polygons shp files I use this cover:
http://www.mappinghacks.com/data/TM_WORLD_BORDERS_SIMPL-0.2.zip
As a points vector layer I use the attached shp file.
If I try to make the intersection from Qgis/vectorial/geoprocess menu I
obtain "invalid geometry", but If I install the sextante python
complement, open the Toolbox and run intersection from the ftools
submenu everything is OK.
Any advice will be very useful
Thanks
Sergio
Sergio A. Estay
Inst. Ciencias Ambientales y Evolutivas
Universidad Austral de Chile
Casilla 567, Valdivia, Chile
Phone: 5663-293913
http://www.ciencias.uach.cl/instituto/ciencias_ambientales_evolutivas/academicos/sergio-estay.php
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120622/8b8559cf/attachment.zip>
