[Qgis-user] QGIS crashes when adding a plugin from QGIS Plugin Manager
Ramon Andiñach
custard at westnet.com.au
Sun Jun 24 17:06:20 PDT 2012
I'm also noting that just updating via osgeo (on windows) will also leave the old repositories in play.
Don't know if the plugin problem happens, will check when I get to work.
-ramon.
On 25/06/2012, at 05:14 , William Kyngesburye wrote:
> I noticed this when testing the packaging on OS X. So I added a note to the OS X readme to delete the previous QGIS.app if there are problems. The OS X installer should be removing this stuff automatically, but it's not, mayeb I need to hardwire cleanup of old files... and someone should do something similar for Linux.
> On Jun 24, 2012, at 4:01 PM, Etienne Tourigny wrote:
>> These decorations are not python plugins, so why do they appear in the
>> plugin manager?
>> On Sun, Jun 24, 2012 at 5:57 PM, Giovanni Manghi
>> <giovanni.manghi at faunalia.pt> wrote:
>>> On Sun, 2012-06-24 at 17:47 -0300, Etienne Tourigny wrote:
>>>> confirmed in linux ubuntu 11.10, so it's not a OSX problem
>>>> On Sun, Jun 24, 2012 at 5:34 PM, Manuel Spínola <mspinola10 at gmail.com> wrote:
>>>>> Update on the problem.
>>>>> When I try to bring any of the 3 options on View/Decorations: "Copyright
>>>>> Label", "North Arrow", "Scale Bar", from the QGIS Plugin Manager, QGIS
>>>>> crashes. For all the other plugins is working fine.
>>> in a clean installation that stuff should not be available anymore in
>>> the "plugin manager" dialog.
>>> Here on Ubuntu 12.04 activating one of the the decorations
>>> (view->decorations) does not cause any crash.
>>> cheers
>>> -- Giovanni --
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
